Alternator wiring
Alternator wiring
Transplanting a 2001 LS1 into something non-GM. I'm using a Megasquirt ECU and a custom wiring harness.
The alternator plug has only one wire. Is that the exciter wire for the internal voltage regulator? That's usually controlled by the ECU. Does it need 12v? or 5v?
If it's less than 5v, I can run an output from the ECU.
If it's 6v or higher, I can use a keyed circuit and a ballast resistor. Which I like better. Alternators can be noisy, and when they start to go bad they can make nasty spikes and surges, which could damage the ECU.
Any idea on how many amps that circuit draws?
Bob,
Here's an update/correction of my answer.
With the 98, I haven't seen anything over 5 volts. However, this is not the complete answer, nor does the same LS1 alternator wiring apply to every year.
Read this for more exact info, and note the discussion of a resistor, or sometimes, a ballast lamp.
Sorry, I had forgotten the particulars.
https://ls1tech.com/forums/conversio...d-voltage.html
Glenn
Glenn
Bob,
Glenn
Glenn
I had read about the resistor. But I also read of some failures, and a voltage reducer was more reliable. A 12v to 6v reducer is cheap and readily available. I just don't know! By the time you read for an hour, one thing contradicts the other and it all becomes a blur.
Anybody know how many amps this circuit draws?
