80 mm throttle body
Ive been reading threads about the potz p&p throttle body from ebay. Seems like a bunch of members are running them and are pleased with them. I just dont know about ebay parts usually you get what you paid for
Hey 99Bluz28, dr_whigham ? For buddy35thle combo you recomend a ported 75mm stock TB. What I'm wondering is, at what point does the 80mm start making sense ?
https://ls1tech.com/forums/generatio...-question.html
I saw this thread but still can't wrap my head around the time the cam/ head cfm would suggest a benefit of larger TB. Also, would buddy35thle benefit from going to a 85mm MAF and Fast Toys lid ?
LS1Tech Premium Sponsor
A little known fact is that you can get a throttle body from an LQ4/LQ9 truck that comes standard at 80mm. Just be sure to take dial calipers with you and measure the back side to be sure it's the correct size. You can usually find them at the boneyard pretty cheap and have that ported if you want an 80mm. I have yet to see a good aftermarket 80mm TB. In all honesty though you wouln't notice a difference between the stock 78 ported and the 80mm ported. When people ask us about porting TBs and Intakes we usually recommend Peak Speed Shop. They are a sponsor on here.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Lonnie
Lonnie
The cam size is different but if your vehicle was equipped with traction control then your throttle cable length is adjustable. It can be a direct swap. I did it several times back in the day. Your stock TB has a coolant tube as well. All you have to do is run a coolant bypass.
Lonnie
Lonnie
__________________
