Pcv valve broken looking for advice
Hey guys i have a 1998 TransAm i was just replacing the pcv valve when i went to remove it the hose end had broken in half . I went to advance help section no one has it. So i looked on here they had a writeup on a alternative to fix it the only thing is they were missing pictures since its an old post can anyone direct me with pivs in the easiest direction to take
If you are talking about the pcv valve line hose, the part number is 12590632. You could always make your own, its not that hard, or you could just buy a new one.
Here is a pic of the part.
make your own setup with a truck PCV. Here's a guide that I wrote.
https://ls1tech.com/forums/generatio...ll-w-pics.html
The guide is actually for catch cans, but you can just do the routing minus cans.
That preformed line is EXPENSIVE from GM.
Thank you roninsonic exactly what i was looking for i did leave the plastic lines in place only thing i did is get a furd 90 degree pcv elbow ,a 3/8 connector, and used 3/8 fuel hose to the hard plastic line. Now i did leave the pcv valve expose a bit and used hose clamps on each end to keep them from coming off. Now is that ok or should i place a 3/4 hose over the pcv??
If your talking about the holder for the pcv valve. I took a piece of heater hose that would slide over the big end of the pcv valve and then a male air hose fitting and slid it into the other end of the heater hose then clamped both ends. Doesn't look the best but its functional.
