Fast 92mm intake install
just curious if anyone has done the manifold swap and not changed out the valley cover bolts. my stock bolt heads looked smaller than the ones they provided so I kept them on and everything worked just fine.
Nope thats playing with fire. The heads of the correct bolts you should have gotten are flat pan head bolts and the stock ones look like this.
the correct bolts look like this
if you didnt change these out you have a high risk of cracking the intake its very common. I'd change them out before doing anything else.
I have to agree with these guys.. I don't care what the current bolts look like, I'd swap them for the correct ones just to be sure. You don't want to make that mistake
If I get the Fast intake, What else do I need to buy? fuel rails? TB? Etc?
I am a pretty good mechanic, but I am rather new to tinkering with these cars. I am just trying to prevent tuning the car more than needed. If the 92 is pretty good, I may just go with that.
I would assume that it is way better than the stock stuff I have on now?
Okay thanks,
