advise on what to buy for best bang for buck
I'm looking at doing something that will give me more performance to my 2000 silverado 2500 4x4. It's a heavy truck and is slow off the line. I already have CAI and pacesetter long tubes.
It's a LQ4 6.0 iron block.
From what i have found here's some things I could do:
high-flow catalytic converters
LSXRT intake with 102 mm Big Mouth TB
fuel injectors from an 8.1 L engine or 42 lb ones.
then a cam... but i'll switch to a LQ9 If going to do that
my questions:
can i bolt on everything and drive it without a custom tune?
Will i need a bigger fuel pump or do anything with the fuel lines with the LSXRT & Big Mouth?
what else would you recommend specifically? (limited budget of 2k)
my questions:
high-flow catalytic converters not needed unless you need them.
LSXRT intake with 102 mm Big Mouth TB may help but there are other tings first
fuel injectors from an 8.1 L engine or 42 lb ones. would not get new injectors unless the current ones are running over 90% duty cycle
then a cam... but i'll switch to a LQ9 If going to do that thats stupid going from a lq4 to a lq9 as the only difference is flat top pistons.
my questions:
can i bolt on everything and drive it without a custom tune? yes to converters, maybe on intake, no on injectors, maybe on cam.
Will i need a bigger fuel pump or do anything with the fuel lines with the LSXRT & Big Mouth? not unless you are pushing over 500hp
my questions:
imo gears and a 2800rpm stall with a tune.
my questions:
my questions:
Intake manifold is a good idea, you won't need new injectors at these power levels.
Basically a cam along with the FAST intake will be your best bets, and a stall as previously mentioned. Those will need a retune of course.
Did you or the PO do a regear when the lift and bigger tires were put on? A lot of people skip that step for whatever reason and lose a lot of the performance feeling having the bigger tires and little stock 3.42's... If so, I'd start there and then work your way up to doing a cam and matching stall. You may also want to look at swapping to an intake from a newer truck (08+). Lots of guys over at performancetrucks.net have made some nice gains with them and you can get one with the newer better flowing injectors pretty easily for a fraction of what the LSXRT intakes cost...
Moderator
Received 1,836 Likes
another vote for gears and stall. On the motor side, the first thing I'd do is mill those heads to get some compression
does the truck have a programmer or custom tune? everything i own i get tuned. it makes a difference without a doubt. but as everyone else has said gears/stall/tune. i would prob go in the order of tune, gears, and then stall though.
Moderator
I'm not sure, to be honest. Either way, I know the compression is lower than optimal, so if they get milled to a 65 cc chamber, he'll pick up some power and efficiency
thx for the info, i have 3.73 ratio.. i tried 4.10 before, didnt like how high it revved on the highway. i like the idea of saving money on the intake ... i found this, will it work on my engine? http://www.ebay.com/itm/L92-Intake-Manifold-With-Fuel-injector-Rail-engine-Cover-/221772744632?hash=item33a2af87b8&vxp=mtr
also, these intakes have 4 bolt throttle bodies looks like. mine is fly by cable.. so i'd have to get another throttle body for this as well? which one? all the ones made for this would be fly by wire... being so new.
I like the 3.73 gears on the highway, plus it's 4x4 so if i change i'd have to change both diffs... so i might have to live with it being 3.73.
I could do the torque converter, I have no idea what stall to get. i've heard from anywhere from 2200 to 2800. i have done some research on what they do, although i still don't understand what the rpm range has to do with anything. at one point i thought it was for racing, where you could hold the brake just under the stated rpm range and then it would lock up when you punched it and let off the brake. but i dont believe that was accurate whatsoever. so... i don't know what to think when it comes to selecting a torque converter. if it allows higher revs taking off.. then that'd be good i'm guessing. not sure.
As said above, stall, gears, tune.
Think of it as a pre-set clutch engagement with a torque multiplier. If the stall is say 2800, the coupling will essentially slip until 2800 before it allows torque to be transferred to the trans. Raising the stall lets the motor hit at a higher RPM (closer to peak torque) for launch and during a shift. The idea is to keep the motor in it's power band (point between peak torque and peak HP) on launch and while in each gear.
thx for the info, i have 3.73 ratio.. i tried 4.10 before, didnt like how high it revved on the highway. i like the idea of saving money on the intake ... i found this, will it work on my engine? http://www.ebay.com/itm/L92-Intake-M...af87b8&vxp=mtr
As far as the rest of the mods go, what are your goals and budget? As already mentioned, milling your heads is an easy way to pick up compression to help power and efficiency. If you do have the iron heads check the price with your local machine shop because it may be cheaper to pick up a set of lightly used 799/243 heads.
For the stall, your intended use for the truck will be a big factor. For a truck that sees any type of towing or is lifted like yours I'd keep it on the smaller side to help get it moving and keep the trans temp down.
Camshaft selection will also be based on intended use and budget. Brian Tooley and Cam Motion make some great "drop in " cams specifically for trucks that make nice power are designed to be used with the cheaper LS6 springs and stock stall. You can also talk to one of our sponsors life Martin at Tick about getting a camshaft custom spec'd for your setup for about the same price as an off-the-shelf cam. If you want to go with a more radical cam be prepared to spend more on matching components like better/more expensive springs, higher stall converter, etc.
