ls6 intake swap... finally
Old 05-26-2015, 06:17 PM
Mappinsj's Avatar
Default ls6 intake swap... finally
so today i ordered everything i need to finally put on my intake, crossover, block offs, and gaskets.
what should i look out for while doing this job, i have heard that i need to watch out for breaking an oil pressure sending unit, where is this unit?
anything else to watch out for?
Old 05-26-2015, 06:26 PM
Exeodus's Avatar
The OPSU is on the driver side rear. The main vacuum hose from the brake booster runs right next to it, so be careful when disconnecting it.
Old 05-27-2015, 06:14 PM
Mappinsj's Avatar
ok this is what up thought. thank you for the response!!
Old 05-27-2015, 06:30 PM
transamtom's Avatar
All the sharp things under the cowl
Change all your sensors,knock and harness and the opsu while your in there.
Have 8 old white socks,some rags and a can of brake cleaner or carb cleaner handy you will see why when you open it up.
Old 05-27-2015, 06:32 PM
transamtom's Avatar
BTW change your oil and filter when your done.
Old 05-27-2015, 06:42 PM
scotty2000ss's Avatar
Make sure the map sensor is seated correctly. Use the low profile valley cover bolts. Don't over tighten! Lol
Old 05-27-2015, 08:14 PM
Majestic9C1's Avatar
take those damn pushpins out of the cowl because the top of your hand will look like an etch a sketch when you are done
Old 05-27-2015, 08:32 PM
wayland1985's Avatar
Op: just curious what gaskets you're going with?
And to the others: what are the part numbers for the OPSU and the socket?
Old 05-27-2015, 09:34 PM
TurboChapman's Avatar
What is the ospu?
Old 05-27-2015, 09:43 PM
Oops. I fixed it. OPSU. Oil pressure sending unit
Old 05-28-2015, 01:38 AM
hanngmcgon's Avatar
Old 05-28-2015, 02:51 AM
Burken01's Avatar
Low profile bolts are for a fast intake install, not ls6 intake.
Don't scare the OP lol
Old 05-28-2015, 04:01 AM
That's right! I'm just paranoid about it lol.
Seen lots of guys getting it done on here lately with the LS6 intake and stock ported/polished throttle body. Good job op!
Old 05-28-2015, 06:03 PM
Mappinsj's Avatar
[QUOTE=wayland1985;18821030]Op: just curious what gaskets you're going with?
i bought felpro gaskets for 25$ shipped from jegs.
i ended up spending 90$ on 2 block offs, the ls6 front crossover, and the gaskets.
including 2 day shipping.
Old 06-03-2015, 06:30 PM
Mappinsj's Avatar
it wasnt pretty but it is done!
Attached Thumbnails ls6 intake swap... finally-img_20150603_133753.jpg   ls6 intake swap... finally-img_20150603_174344.jpg
Old 06-03-2015, 06:33 PM
Paal's Avatar
Did you match port the intake?
Old 06-03-2015, 07:05 PM
transamtom's Avatar
So I guess you figured out what the 8 old socks and brake cleaner were for
Old 06-03-2015, 09:05 PM
Mappinsj's Avatar
I did not port match. a clean swap, it is very clean power in the mid range
Old 06-04-2015, 03:11 AM
fuqtianba's Avatar
Quick Reply: ls6 intake swap... finally
