Coilpack Relocation Help
I have searched to try and find the answers first and i have found that i need opti spark terminals and a Universal Wire kit so i can cut them to length.
Heres whay i found....
PT# 46052 Taylor Opti-Spark End Terminals..... But what wires?? I am wanting to use Taylors also.
Do i use.
PT# 73051 Taylor Spiro-Pro 8mm Universal Wire Kit, 90 degree boots, BLACK
or
PT# 73055 Taylor Spiro-Pro 8mm Universal Wire Kit, 180 degree boots, BLACK
So the real question is do i use 90 degree boots or 180 degree boots or is there a straight boot kit and if so does anyone know the PT#?
Thanks
Kyle
Do i use.
or
Thanks
Kyle
I am going to buy them from Thunder..... the part numbers i listed plus what ever it costs for the other parts from Home Depot
04-73055 Taylor Spiro-Pro 8mm Universal Wire Kit, 180 degree boots, BLACK $53.99
04-46052 Taylor Opti-Spark End Terminal Kit $11.99
Total $65.98 Before shipping. Then you have to cut them to legth and crimp then your self......
Kyle
Kyle
Kyle
Kyle
Originally Posted by CANNIBAL
Kyle, what's the correct crimper to use? Also, what wire are you gonna use?
We are just using a regular crimper for any wire...... just make sure you do it enough and have full contact......Thunder has a tool on there site for $9.99 if u want to buy that..... ill post pics when im done..... i just have to decide were i want them now.
Kyle
Any problems since the relo? I read recently how they went to the valve cover mounted coil packs to put them as close as possible, because they had problems during prototype phases with heat exposure etc...
Never did it so i dont know....... i do want to try it though and clean up the bay some...... one of these days........
Kyle
