LQ4 Ls1 Pilot bearing
I have a 06' LQ4 with an 02' T-56, I installed a new clutch and slave cylinder, bolted everything up, and dropped it in my car... I never touched the pilot bearing, and now that I think about it im not even sure if it had a pilot bearing, the tranny slid in super easy.. and the alignment tool was fairly loose (I know im a dumb *** )
This is the only picture I have before I bolted trans on
http://www.flickr.com/photos/55665137@N05/5273386778/
Is there any chance that the LQ4 had the correct pilot already in it.
Or should I 100% pull the motor back out, unbolt trans, check, and install a 2002 Camaro Pilot Bearing.
Thanks for your words of wisdom..
Sorry for waking the dead,
I'm looking at same gen LQ4, but I have a 1994 T56 that I converted to LS using Rockland's adaptation kit (with mid plate and longer input and other things).
Rockland said I needed needle bearing from 93 camaro.....They made that whole kit so I'm inclined to believe them, but that sounds wrong, especially since you guys said like 02 camaro.
The kit was supposed to make it so that it allows this t56 to work on any LS style engine.
Also, if it makes a difference, I'm using the RXT twin clutch kit for LS1 from McLeod.
Please let me know
Please let me know
