Doing a wire tuck, what's this connector??
Old 02-15-2016, 06:58 PM
JustAFooL's Avatar
Default Doing a wire tuck, what's this connector??
Got Ina rush during my build last winter so I've tore it back down to tuck all the wiring. Found this connector between the #2 and #2 fuel injector connections. Looks like it could easily be soldered together but I wanted to ask first.
Old 02-16-2016, 09:39 AM
brobinson216's Avatar
That's an injector connector. If you had a terrible misfire you've found the culprit.
Old 02-16-2016, 09:50 AM
Zmg00camaross's Avatar
X2 injector connector. It's mucho needed lol.
Old 02-16-2016, 07:53 PM
JustAFooL's Avatar
My picture is a little deceiving. I'm holding the connection for the injector. I was talking about the 3 wire connector below it. is that tied into the injectors?
Old 02-16-2016, 08:39 PM
Where is that harness running to?
The downward side toward the bottom of the motor is the direction I'm referring to.
Not confident I've ever seen it, and if I have it doesn't look familiar.
What's the vehicle?
Old 02-16-2016, 11:44 PM
blk00ss's Avatar
Looks like the cam sensor to me.
Old 02-17-2016, 05:14 AM
JustAFooL's Avatar
What's the vehicle?
It a 98 Camaro. The harness just runs alongside the passenger head. Has all the injector connections in it and something for the AC I believe on the end. That funny bracket your seeing on the head is the CBR alternator relocation kit.
The thing is that the wires coming into the connector are all the same color as the ones coming out. I don't see why I can't just solder them together and get rid of the big bulky thing but I would definitely like to know first.
Old 02-17-2016, 10:41 AM
jrpimp00's Avatar
Air or EGR? I have it on my 98 as well with !AIR !EGR
Old 02-17-2016, 01:55 PM
JustAFooL's Avatar
That's exactly what it is. I deleted them years ago and I remember tucking the wires inside now. Thanks man!
Old 02-17-2016, 08:16 PM
JustAFooL's Avatar
Never mind. That's not it. Found those wires. What the hell is this thing??
Old 02-19-2016, 10:48 AM
Zach-R's Avatar
I have wondered the same thing. It's hideous haha. I see no harm in soldering it all together. I don't know what it's for though either. I still don't know what to do with the ac plugs and wires. I hate to permanently remove those.
Old 02-29-2016, 06:42 PM
Zach-R's Avatar
Figure anything out? I'm about to solder mine up like mentioned. Wish there was something I could do with the ac wires too. I no longer have ac.
Old 03-02-2016, 09:10 AM
lsfanatic's Avatar
It's the cam sensor wiring. For some reason the actual cam sensor plug runs to the male side, and the PCM is female side. If you test continutity you'll see what im talking about. Not sure why there is a connector inline with the cam sensor, maybe they thought some cars might have the cam sensor in the front? Idk.
I had a whole 98 harness apart to delete emissions and repin it for a 411, soldered those wires together and shortened them.
Old 03-02-2016, 09:34 AM
greenvortec97's Avatar
Runs to the cam sensor, if you unplug it you lose your Tach lol.
Was put there by the factory for diagnostics
Old 03-02-2016, 10:54 AM
Zach-R's Avatar
Awesome thanks guys. Whats the odds i may one day need that connnector for diagnostic reasons?
Quick Reply: Doing a wire tuck, what's this connector??
