Oil catch can... which one to get?
Old 03-17-2016, 12:01 AM
FCar2000TA's Avatar
Default Oil catch can... which one to get?
Elite Engineering, WS6 Store (Norris Motorsports)Speed Inc (UPR Products), Saikou Michi, RX Speed Works??
Elite = $160
Norris = $100
UPR = $110
Saikou = $165
RX = $200
Mighty Mouse = $180
Elite has a "clean-air oil separator".. does that mean that the catch can won't separate oil from air?
Old 03-17-2016, 08:48 AM
.boB's Avatar
It's a catch can. Nothing magical about it. You can make one from stuff in Home Depot for
Old 03-17-2016, 09:19 AM
Jamie R.'s Avatar
Catchcans.com and I think 90 bucks. Cant beat that!
Jamie R.
2k Ta
Old 03-17-2016, 09:26 AM
Hou_tx_ss's Avatar
Mighty Mouse. Has a check valve built in.
Old 03-17-2016, 09:35 AM
FCar2000TA's Avatar
I had not seen that one. The PCV version has a built in PCV valve too.
Old 03-17-2016, 04:17 PM
FCar2000TA's Avatar
Since the factory PCV stuff crumbled when I took the intake off, I decided to get an LS6 valley cover from WS6 Store. I threw in the Norris Motorsports catch can. Should work well for my stock cube motor.
Old 03-19-2016, 03:01 AM
juniorssrollin's Avatar
+1 for Mike Norris
Attached Thumbnails Oil catch can...  which one to get?-img_20160312_152330491.jpg
Old 03-19-2016, 08:41 AM
Chris25's Avatar
I have the Norris catch can works great.
Old 03-19-2016, 01:51 PM
TAEnvy's Avatar
There was a test done and posted on corvettefoum.com.
Said the mike norris can was probably good for stock cube na motors and thats what they recommended for most, but IIRC they said the elite, rx, and amw (maybe) worked better.
Ive seen a link posted here on tech, maybe someone can find it
Old 03-19-2016, 06:02 PM
ironmikektm525's Avatar
Bought mine from corvettemods. Nothing fancy but works great! It's clear so you can monitor the oil. Been running it for 2 years with no problems. Can't beat it for $50!
Old 03-20-2016, 08:46 PM
King23's Avatar
+1 for Mighty Mouse I had a question about his can emailed him and he responded fast.
Old 03-21-2016, 02:29 AM
fedoantie's Avatar
Old 03-21-2016, 08:15 AM
Jamie R.'s Avatar
mikenorris and catchcans.com look identical
Jamie R.
2k Ta
Old 03-21-2016, 09:32 AM
MIGHTYMOUSE's Avatar
great thread. they are not all the same or do the same things. research wisely!
Old 03-21-2016, 10:10 PM
GMW96's Avatar
I have elite and like it.
Old 03-22-2016, 06:56 AM
jrpimp00's Avatar
MM can here with my boosted setup. No problems and good guy to deal with
Old 03-22-2016, 09:59 PM
O1BlackSS's Avatar
Just installed my MM PCV catch can with LS head mount on my 2001 Camaro SS. Only needed to get about 8 feet 3/8" fuel line hose, I used SAE30R7 hose, temp. rated -40 to 275. Install was a breeze. Looks great, works perfect, very well engineered. Hardest part was taking out the OEM PCV lines. Would recommend this setup to anyone. Pictures will be posted soon. Contact Dave at Mighty Mouse Solutions, he knows his stuff.
Old 04-17-2016, 11:48 PM
andrew69_04's Avatar
I have the elite. pretty nice piece. I'm happy with it
Old 04-18-2016, 03:28 AM
stinaores's Avatar
Old 04-18-2016, 11:10 AM
Chris Paveglio's Avatar
A very reputable tuner I just took my car to said the MightyMouse was the only one that really worked. I have the PCV version, so not sure if he meant that kind only or all of them. But good to know either way.
edit-
I've been reading more and seems like RX has been tested to remove more oil than any others. About half way down on this page is a very lengthy test done by a guy with 2 cans, in a thorough scientific manner. http://www.silveradosierra.com/vorte...n-t447361.html
Quick Reply: Oil catch can... which one to get?
