LS6 valley cover.... PCV valve still needed? Fresh air needed on both valve covers?
I am reading threads that say yes and no. So..... I just ordered the 12577927 LS6 valley cover and the Norris Motorsports catch can. So....
Do I still need a PCV valve?
Should I be running fresh air from the throttle body to the driver side valve cover along with the passenger side (makes sense to get fresh air on both sides of the motor), or is fresh air only needed on the passenger (stock) side for some weird reason?
Seems to me that the best set up would be a "Y" connector from the throttle body to both valve covers.
With the LS6 valley cover you can remove all of the factory PCV hoses. Plug the rear ports on the valve covers because you no longer need them. The catch can should have two ports on it. Run a hose from the valley cover to the inlet and the outlet should be routed into the intake like the factory setup. No need for a PCV valve. If the catch can isn't vented, then put a breather on the passenger side valve cover or the oil cap, your choice.
There are two "LS6" valley covers. The #12577927 (was in the CTS-V and GTO) which has the PCV valve built in and #12568002 (C5 LS6) which does not and you will want to run a separate PCV valve.
Everything I have read is that you run the vent line to the passenger valve cover and just run a hose between the two covers on the rear. Or you could y them at the front, it would basically be the same thing.
Also FYI you generally don't want to run an open breather along with the PCV system(its either one or the other), you are drawing in unmetered air into the engine (like a vacuum leak). If you want to run a breather make sure it has a 1-way check valve on it, allowing air out of the crank case but not in. Then you need to hook up the hose between the throttle body and the valve cover, that allows metered air (since its after the MAF) into the crank, the intake pulls vacuum out of the crank through the PCV line, otherwise its pulling from that filter on the valve cover (into the crank, then through the PCV line, then into the intake).
