450-500rwhp from a n/a 5.3l
Hello,
I recently bought a 2002 5.3l vortec, lm7, and will put a t56 behind it to eventually shove it all in my camaro. I want to make 450-500rwhp, what parts would you huys suggest?
My thoughts:
Stock bottom end
232/234 comp cam ( rpm range 2400-7200)
Comp cam valve upgrade kit
243 heads( decked about 0.010" )
Fast Lsxr 92mm intake
66 lb/hr injectors
Anything else?
My thoughts:
Stock bottom end
66 lb/hr injectors
Anything else?
That really depends on the money you're willing to throw at it. Usually, it's a waste of time and money after all is said and done. Will not be reliable nor will it be a friendly car to tune or drive.
Moderator
Received 1,836 Likes
it won't be enough unless you plan to spin 8000 rpm. You look at some of the most highly optimized builds on here at 5.7 and 6.0 L, that's what it takes to hit 500 on those motors. Your parts list doesn't approach those builds and the motor is smaller. Hammers guess is a pretty good one.
Well i plan on boosting anyways, i just wanted at least 450 na. Yes i did think about it too, with the stock 243 ls1 heads fit without boring?
And yes 243s fit just fine, they actually come stock on the more recent 5.3s
Assuming from your username you have an 89 camaro, there isn't going to be a bolt in kit. If stock LS exhaust manifolds will fit, Id use those in a heartbeat with a custom hotside to connect to the turbo and cold side. 4" intercooler, 3" cold side piping, 2.5" hotside piping. T70 turbo with a .81 A/R will work nicely with some room to grow. Plenty of good stuff out there and info in the forced induction section on this site. Walbro fuel pump and 60# injectors on a stock rail. Don't touch the bottom end assuming its in good shape. I would do pushrods and springs and something like an LS6/LS9 cam as theyre cheap and will make great power with boost.
I think ddnspider really laid out a pretty good list for you.
You really need little more than heavy duty pushrods, heavy duty valve springs, and new injectors/fuel pump to get started. Even the LM7 stock cam does well with boost. A LS6 or LS9 cam would be better, and they are cheap, but not necessary.
