proof that cut out lowers 1/4 mile time?
I have 98 Camaro ls1 with fast 92inake an tb with some suspension mods going to be adding a stall converter I have long tube headers with ORY an gmmg muffler... can anyone tell me that a cut out will change my 1/4 mile time at all im trying to do an all bolt on car an get every tenth
Probably will. My last build I dropped .2 in quarter. Later I did a tune to exhaust c/o's and dropped an additional .3 I have used c/o's in all my builds over the last 40 years and the one thing I consistently noticed is the more HP I yanked out of the engine the more I gained from the c/o's. I would suggest you get a good tuner so you can tune at the track for open exhaust and switch back for DD(if thats what this is)
Yes, I'm sure you leave a few horsepower on the table by not having a cut out and cat- back specific tune. But, you don't "need" to have a tune for both
alternatively you could use a flowmaster y merge 3" into 3.5" or 4" with a good bullet and turn down welded on it (even a 3" bullet), will flow nearly as well as duals but be lighter and it sounds great
a cutout can make a difference on some and not on others, just depends
My cutout makes a noticeable difference both at the dyno and on the track.My setup would favor a larger free flowing exhaust having the turbo and cutout open before my gmmg was good for 20+whp and about 30tq.My tune was dialed in with the cutout open and then tweaked to find a happy medium for driveability both open and closed. I can see for some that a cutout wont net much hp gain from an already efficient setup other than just making ground pounding noise.
My old 97 Lt1 M6 car went from a 14.05 to a 13.77 with the same 2.0 60ft time. Only change was I added a cutout before the axle. Then again I could've just gotten better at driving the thing.
