Fuel rails for FAST ?
There are quite a few options out there for fuel rails now. What fuel rails are those of you with FAST intakes running ? Pros and cons ?
http://www.summitracing.com/parts/fst-54028-kit
If you are talking about a fast 92mm intake, then there is no need to upgrade the factory fuel rails unless for looks.
Last thing you want is to buy some fuel rails off ebay or off some backyard wannabe mechanic in the classifieds that have no hardware or no way of connecting it to your factory system, assuming your fuel system is still factory. Make sure the **** comes with everything that is needed to hook it up to your intake and the fuel system that is in place. 102mm fuel rails don't bolt up to 92mm fuel rails, and vice versa. You can drill new holes for the brackets, but better to just get the right parts.
If you decide to go aftermarket rails, make sure you get all the fittings and hardware and not just the rails themselves, and make sure you get what is necessary to hook it up to your factory system.
I'm running a 102 with LS3 injectors and LS2 fuel rail.
Pro - no need for spacers for the fuel rail however...Depending on what type injector you are using you may have to.
Con - Have to spring for the LS3 injector spacers ($39) and EV1 to EV6 adapters ($16)
Thanks
