Fuel Injectors - What is good for what?
Does anyone here have a list of what pound injectors is recommended what kind of modifications are done to what engine? Who he is the specialist on this topic?
Restricted User
Just get big enough injectors to give you a little headroom. As long as the injectors are high impedance, you can make 200+ lb/hr injectors idle on a stock computer.
On this Forum: Is there a complete list of injectors part numbers to flow rate? Or injectors to horse power, or from stock injectors to a upgrade based of modification?
Restricted User
There are probably 100,000 injector part numbers out there. As far as I know, there is no list of all of them.
Stock LS1/6 injectors are around 30 lb/hr and are good to around 400whp on gas if you push them.
Flow is proportional, so 60 lb/hr would be good to 800whp on gas if you pushed them.
Do the math from there.
LS1Tech Premium Sponsor
For a N/A build use this formula. (HP/2) / 6.4 = Injector psi.
So: 500hp/2 = 250. 250/6.4 = 39lbs.
That gets you an injector working at 80% duty cycle. Then just shop for that size or close to it.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
