Belt part number needed help please
Old 03-15-2017, 10:12 PM
Ogoz23's Avatar
Default Belt part number needed help please
Hi guys I need help from anyone that can help me with a part number. I need a 6 rib 118 inch OC belt.. the 118.25 that I found is a tat to big. I'm going by the marking on my tensioner.thank you in advance
Old 03-20-2017, 01:18 PM
Jontall's Avatar
Dayco 5061178 is .05" shorter.
Old 03-20-2017, 10:24 PM
Ogoz23's Avatar
Thank you but that belt is actually 118.41 outer circumference and 117.75 effective length. I need 117.50 - 118" outer circumference.
http://www.autozone.com/cooling-heat...996_23387_2425
Old 03-21-2017, 04:42 AM
Jontall's Avatar
https://www.google.com/url?sa=t&rct=...EjfcXAKfNqFWjw
Old 03-21-2017, 09:09 AM
Ogoz23's Avatar
Hi jontall I didn't see any 6 ribs .. did you see anything in that list that might work for me ?
Old 03-21-2017, 04:24 PM
Jontall's Avatar
Any belt number that begins with K06xxxx is 6 ribs. The next 4 numbers (x) is the length. (K061145)
Old 03-22-2017, 02:12 PM
Ogoz23's Avatar
Doesn't seem to be any belt there that's 117.50 to 117.75 Outer circumference.
Old 03-23-2017, 10:49 AM
Jontall's Avatar
Then you need to go bigger or smaller on the idlers/ pulleys.
Old 03-23-2017, 10:59 AM
Ogoz23's Avatar
That's what I was wondering , can you guide me on witch idler pulley I can buy that might be bigger or smaller . I searched ls idler pulley size but really nothing came up
Old 03-23-2017, 01:17 PM
Ogoz23's Avatar
I swapped this two pulleys and it worked , you think I'll have an issue
Old 03-23-2017, 02:39 PM
Jontall's Avatar
If the pulleys/idlers are good, you'll be fine.
Quick Reply: Belt part number needed help please
