TSP's true duals tubing size
I just wanted to know if TSP's 3-inch tubing on their true dual exhaust is going to be too big for stock engine with a few bolt-ons. Like if my low end will suffer because of too little back pressure from the 3-inch piping.
Originally Posted by CaMaRoZ28LS12000
So should I just have an exhaust shop fab a 2.5 inch true dual for my car instead of getting the TSP system?
i think dual 2.5" would be better for a light bolt on car, as dual 2.5" flows similar to a single 3" because of the added resistance due to added surface area on the walls of the tubes. Dual 3" flows like single 4" and can handle just about anything you throw at it. As far as losing low end, with an x-pipe and intake mods, then you shouldnt see much loss at all.
-Stu
-Stu
LS1Tech Premium Sponsor
On a stock-internal car, you will feel a little bit of a loss in low-end torque. However, it will still give you a nice increase in power for your usable powerband (i.e. the RPM band you'll stay in when making a pass at the track). The car will still pick up some nice power, but it won't feel as torquey down low (2,000 RPM area) when cruising around town. We wanted a system that would flow well deep into the 10-second ET range.
Let us know if you have any other questions or concerns.
Thanks!
Trevor
Texas Speed & Performance
Thanks!
Trevor
So how much loss would I see in low end torque if I used the 3 inch exhaust? And when you say tune, do you mean a dyno tune, or like a predator type tune?
Are there any plans to offer a 2.5inch version of your exhaust in the future? Because I was seriously considering your exhaust but the low end loss is really my only concern, since my car is a daily driver.
