Do I need IAT?
Do I need IAT?
My pullout didn't come with the airbox so I have nowhere to plug my IAT sensor into. Can I just remove the pins from the PCM or do I have to wire a resistor in?
STF Veteran
You will get a SES light if you do not install it, or as Andy said out the resistor in. You could just extend the wires and let it hang in the fender well, but it'd be just as easy to cut a hole and install it.
Moderator
If it's not going to be measuring true inlet air temp
then just use a resistor - last thing you want is for
it to be flapping around in the hot engine bay,
measuring an irrelevant high temp and pulling your
timing back.
If you went to an 85mm Delphi MAF those have the
IAT in-throat, pinned out on the 5-pin connector.
Casper's adaptor harness will hook 'em up or you
might just get a junkyard harness end off a truck
and solder it up clean.
timing back.
