02 sensors...02 sims...ahhh
ok i just got my pacesetters in the mail, speedy delivery! i have a couple of questions.
1. there is 1 hole in each header, for 02 sensors i thought, but my friend was telling me that i NEED o2 sims. my ses light is already on from !air so i thought '**** the sims, already got on the ses light' but he sais without them, car will run bad...if i do need them...where do they go? someone explain all this to me please.
2. with the headers i got this '02 sensor relocation kit'. it comes with a hollow black tube, some bundled white wire and some fuse looking things in little red capsules..what is this?
very confused...thanks for the help
Skip the sims and just get the codes deleted with LS1 Edit later on.
yeah, you dont really need the simms, and to make sure you know you have 4 O2 sensors, there are 2 on each side of the exhaust (2 on driver side, 2 on passenger side), the 2 infront of the cats are the only ones that really matter, they tell your computer important stuff, so you ll only have to extend those front ones
Yes, you need to run O2 sensors. Your car had four from the factory but, you only need two with the headers. You'll connect the factory wires from the front set to the sensors. The wires that went to the rear factory sensors can be just unused OR you can plug sims into them to keep from getting a SES light. It won't hurt anything if you just leave them unpluged (unused). You should have got some wire extentions (just plug and play) with those headers because the front wires will be to short to reach the new location. That '02 sensor relocation kit' requires cutting and splicing to achieve the same effect. If you didn't get the plug n play wires, order them. Much easier than the splicing method.
na shawn you answered my next question, about the extensions they sent, yes i will order some plug and play extensions. thanks for all the help guys! hopefully ill be in atleast a couple weeks with the new duals!
1 Post
