Do ported TBs have larger blades?
Old 09-28-2004, 12:32 PM
BADSZ28's Avatar
Default Do ported TBs have larger blades?
As stated in title. Do porters put in larger blades, or just clean them up, block the holes, and fix the stop. This also may vary by porter. Who does and who doesn't?
Thanks
Old 09-28-2004, 12:37 PM
Kleeborp the Moderator™
MeentSS02's Avatar
My Jantzer piece uses the same size blade, as I'm sure most others use as well. Most just do as you say...clean them up, fill the holes, and fix the stop.
Old 09-28-2004, 12:41 PM
SScreaminDemon's Avatar
It depends on how much you are porting it. Too much and you'll have to get a larger blade.
Old 09-28-2004, 01:25 PM
cyphur's Avatar
um if you know where you can get a larger blade, i'd love to hear it. that'd be a BITCH. **** up the seal and you're DONE. time for a new tb. or time to spend a hell of a lot of time with some jbweld, a dremel, and the blade trying to fix the seal. thats why its always important to keep track of where that area is, and to leave it alone when porting your own. its a restricted area lol.
Old 09-28-2004, 01:55 PM
BADSZ28's Avatar
Yeah I heard to many horror stories with home porting. I just wanted to see if the pros do it.
Thanks
Old 09-29-2004, 02:01 AM
NLang's Avatar
Porting is just smoothing out the passage before the throttle blade. Enlarging the actual bore is called boring. That's the one and only case that'd need a larger blade. I had a company that overbored, ported, polished, shafted, ect. throttle bodies. The factory LS-1 unit can be bored to 78mm max with just a little material added. I actually still have one brand new 78mm unit on a shelf if you're interested ($240).
The 'pro's' know where to stop-right after the vortex. The best/easiest way for a first-timer to port their own unit is to first trace around the blade with a sharpy before dissassembly. This way you'll know where exactly to stop before you ruin the unit.
Let me know if any of you guys plan to try. I've done hundreds of units for many different yrs, makes and models. W/o a milling machine, lathe, or know-how to make the tools required to even make a blade, you at home cannot overbore. But, you can do some porting and maybe even shafting that'll atleast help a little.
Old 09-29-2004, 04:40 AM
LS1LT1's Avatar
Question
What about 'sharpening' or thinning the upper edge of the stock sized blade so that it cuts the air better when open, is that common practice (my PTB doesn't seem to have that done)?
Old 09-29-2004, 07:28 AM
GM Muscle's Avatar
I bought from a shop that sells on ebay and mine did come with a slighlty larger blade. It's a pretty nice piece and the blade seals great.
Old 09-29-2004, 12:21 PM
NLang's Avatar
Being that it has a slightly larger blade, it also has a slightly larger bore. That's just how it works...
Never 'knife-edge' a throttle blade. You can ruin the seal, and also cause it to stick shut if closed rapidly.
Old 09-29-2004, 05:05 PM
LS1LT1's Avatar
Thumbs up
Ok, thanks.
Old 09-30-2004, 12:50 AM
Ferocity02's Avatar
"Porting" LS1 throttle bodies isn't really porting... It's more like smoothing out the airflow.
Old 09-30-2004, 01:10 PM
NLang's Avatar
That's what a port does bud... 'Smoothing' would be more related to deburing, which isn't really needed with these becasue the casting is already pretty smooth. With these, you remove the vortex, port the new transition, shave down the beginning of the opening, and maybe fill and drill the IAC/PCV opening. Shafting isn't porting, but that's another good way to let in more air @ WOT.
