Help separating stock Y for cat-back!!
Originally Posted by Uno99
Any tips or tricks to help separate the stock y-pipe from cat-back. IT IS STUCK TOGETHER. I don't want to cut it.
First covered the joint in wd-40 and let sit for 30min-1hr
Then after the cat-back was loose I vertically twisted it up and down till it came off (a friend makes this much easier- each person grabs one side)
Hope this helps, it can be done, just takes some effort.
1 Post
Originally Posted by Keenov
Maybe some PB Blaster or White Lithium (doubt that will work as well for this type of situation).
I had to torch it. Heated it up for a little and it slide right out.
Ditto..
We used a Propane Torch to heat it up, and alot of wiggling.
