SLP vs Spohn vs BMR
Old 11-25-2004, 09:57 PM
MachoCamacho's Avatar
Default SLP vs Spohn vs BMR
What brand is best for what suspension upgrades?
LCA's and Torque arms especially
Old 11-25-2004, 10:01 PM
Beast96Z's Avatar
Spohn....... There T/A for headers is awesome, and gives you clearence to run exaust.
The BMR has a bar that runs all the way across the bottom of the car that really effects things like that. If your talking about T/A's that mount to the tranny, either the BMR or the Spohn will be fine.
Old 11-25-2004, 10:07 PM
oh btw, i'm getting kooks longtubes and tsp true duals if that effects it.
Old 11-25-2004, 10:23 PM
Beast96Z's Avatar
The true duals deffinatlly effect it. You'll have to go custom if you get the T/A that mounts like the one pictured above. If you get the one that mounts in the stock location, you can run the TSP duals.
Old 11-25-2004, 10:59 PM
fastsspr's Avatar
Danm that exhaust look nice!!
Old 11-25-2004, 11:11 PM
silverZ98's Avatar
your right the bmr does go all the way across. but the bend in the bar is in the same place as yours. so i dont see where it effects things that much. you chould run your same dual set up with the bmr too.
Old 11-26-2004, 12:46 AM
Mcduffys's Avatar
You can always try the Random Tech...I have no problems with my True Duals!
Old 11-26-2004, 12:53 AM
so A: would the BMR adjustable torque arm mount with the TSP true duals? and B: does SLP have anything better than BMR does?(reason being because i can get like 15% off of BMR stuff with a group purchase from Fbody once in a while)
Old 11-26-2004, 12:23 PM
Beast96Z's Avatar
I wouldn't even put SLP in the sentence with these companies. Another thing, you haven't answered whether or not you are buying the T/A that mounts in the stock location or the one that mounts halfway down the driveshaft tunnel like the picture I posted........
Old 11-26-2004, 01:39 PM
I'm getting the TSP true duals so i would like to get whatever i can that mounts correctly with it...
Old 11-26-2004, 01:56 PM
conan's Avatar
Just another option, UMI. I have there lca's and panhard, there quality is just as good as what i have seen from bmr, cheaper too. I think they have the adjustable tq arm out now. they are also a sponcer.
