TPIS 90mmTB vers Fast 90mmTB?
Old 11-30-2004, 12:20 AM
beardWS6's Avatar
Default TPIS 90mmTB vers Fast 90mmTB?
Just curious , is there any differance between the 2. I have the Fast and it`s killing me. Taking the car back and wanting to go with TPIS. Will I loose and by doing this. Thanks!!
Old 11-30-2004, 12:41 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
I'd like to know too, as I may be encountering a similar dilemma soon (90mm Fast TB goes on next week- I need to have my options ready if it acts up).
Old 11-30-2004, 12:42 AM
cyphur's Avatar
do you have the original provision of the FAST tb? or revised? i was under the impression that with the fixes implemented, the new FAST model was issue free(and damn well should be for $475).
Old 11-30-2004, 12:46 AM
SRfastZ's Avatar
what you mean its killing you ?
Old 11-30-2004, 01:20 AM
beardWS6's Avatar
Major surging issues, and now the TPS is acting up. Will not let the tranny downshift when I nail it. Jayson and crew have been fighting it. Granted the shifting issue and surge wasn`t going on anymore when I picked it up. Now its just getting worse!!!
Old 11-30-2004, 10:18 AM
JS
JS's Avatar
Mine has a slight amount of surge in open loop,I'll take care of that today via tuning.
Once its in closed loop the car idle rock steady at 900rpm and revs freely when u crack the throttle with no surging of anykind.Did u do the peen mod on the shaft and did u drill the set screw into the throttle shaft?
I did the mods that needed to be done and my tb work flawlessly.
Old 11-30-2004, 10:57 AM
!LS1 11 Second Club
I'm glad the mods worked for you. BUT, the fact that you need to mod this new, expensive TB to get it to work right is unacceptable.
If and when mine acts up, it's being sent back right away.
Old 11-30-2004, 11:32 AM
JS
JS's Avatar
I agree for the $$ it shouldve been done but to mod it is easy.
No biggie...
Old 11-30-2004, 04:17 PM
SRfastZ's Avatar
so which one is better to buy ?
Old 11-30-2004, 04:42 PM
beardWS6's Avatar
I believe the TPIS is the best buy. I`m taking my car back to MTI Wensday and getting them to take the fast off and put the TPIS on. I`m spray a 150 shot and don`t need the surging issue at all!
Old 11-30-2004, 05:00 PM
!LS1 11 Second Club
I wonder if anyone from FAST reads these posts?
Old 11-30-2004, 05:15 PM
LawmanSS's Avatar
The only differences I know of are that the TPIS unit actually lines up with the neck of the intake better than the FAST (scratch head now) and the TPIS does NOT have a provision for the metered air line that connects to the valve cover...
EXACTLY!
Been wondering that myself...I guess not!
Old 11-30-2004, 05:27 PM
cyphur's Avatar
they do. thats one reason they found out about the issues in the first place...customers from 'tech pointed them this way and said "look at all these f#$%'n issues".....
Old 11-30-2004, 05:28 PM
Phoenix 5.7's Avatar
hows the cost compare, i know tha FAST is around 450, but dunno about the TPIS
Unaffliated Racing's Avatar
Yes. Any and all posts of Comp performance group products are seen, noted, and dealt with accordingly.
Old 11-30-2004, 05:33 PM
!LS1 11 Second Club
That's good to know.
Old 11-30-2004, 05:34 PM
cyphur's Avatar
excellent....
Old 11-30-2004, 07:47 PM
beardWS6's Avatar
Then why are will still having problems with them. Do they not fix the problem before they sell them. Mine is only 4 days old. I thought they had fix everything. I`m having The same issues everyone else has had!!!!Whats with that. What do you mean dealt with accordingly. !!You buy it, have problems with it. Take it off you car and send it in and we will fix it then. Car is down and the extra cost. Whats with that!!!
Old 11-30-2004, 08:08 PM
O2bqwik's Avatar
Old 11-30-2004, 10:22 PM
SRfastZ's Avatar
is there a website for the TPIS unit and is it also 90mm
when you change the intake for a fast 90mm or TPIS do you also change the Throttle body or leave the stock one on ?
