what else do i need for LT install?
Old 12-05-2004, 12:11 PM
Nsty98LS1's Avatar
Default what else do i need for LT install?
i'm probably going to order pacesetter lt's and catted y from TSP. i know i need 02 extensions but do i need anything else. do the headers come with bolts, gaskets and everthing. thanks in advance.
Old 12-05-2004, 12:29 PM
~RedLineLs1~'s Avatar
Well the headers come with everything you need, but considering you are ordering the pacesetters, they come with cheap paper gaskets. I would highly recommend ordering different gaskets for the install, to avoid leaks and such. Good luck with the install.
Old 12-05-2004, 12:58 PM
cyphur's Avatar
Just get another set of stock gaskets from your dealership if the ones on your car turn out looking like crap. They aren't too expensive.
Old 12-05-2004, 01:34 PM
Caribe's Avatar
New stock gaskets and I would recommend locking bolts for the headers.
Old 12-05-2004, 10:04 PM
LS1 Sounds's Avatar
If you are keeping the AIR system hooked up and you get a fluttering sound after the install, you may need some restrictor plates: http://riptide63.homestead.com/restrictor.html
Old 12-06-2004, 03:58 PM
01SSRMS's Avatar
In a similar situation, Picked up a set of headers and a ypipe w/cats. Do I need 4 O2 extensions total? or are they just necessary for pre cat or post cat. Any info. would be great.
Old 12-06-2004, 04:22 PM
cyphur's Avatar
rear o2's will reach. only need extensions for the fronts.
Old 12-06-2004, 04:42 PM
Z28Venom's Avatar
When it comes to header installs, just about any question you can ask has all ready been asked and answered 10 x's over.. All you have to do is search..
Old 12-06-2004, 04:52 PM
LS1FIRE's Avatar
I orderd Pacesetter LTs from TSP and it came with wires to extend to front 02s to the headers. And reused the stock gaskets.
Old 12-06-2004, 04:54 PM
LS1FIRE's Avatar
You also may need 02 sims. It is not neccesary to have them if you can live with the SES light being on.
Old 12-06-2004, 08:40 PM
Nsty98LS1's Avatar
i ordered the catted y pipe and unfortunately for me they are out of stock for now but at least the headers are on the way and the y pipe should be available in a couple weeks. so i'll hopefully have a good project for the begining of the year.
Old 12-06-2004, 09:59 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
why locking bolts?
Old 12-06-2004, 10:10 PM
TAQuickness's Avatar
patience.
Old 12-06-2004, 10:37 PM
01_SuperSlow's Avatar
Like others said, use stock new or used, depending on condition, exhaust gaskets.
Reuse the exhaust manifold bolts. If the ones that came with my Hooker LT's were ****, I don't think the bolts with the pacesetters are any better.
Old 12-06-2004, 10:42 PM
Keenov's Avatar
Originally Posted by 00ls1
why locking bolts?
The given bolts are known to back out. We installed them on my brothers car and three of them backed out during a 10 minute ride home from the shop.
Installed locking bolts and no problems since.
Old 12-06-2004, 11:05 PM
00ls1's Avatar
do the ARP bolts have a tendency to back out??
Old 12-06-2004, 11:24 PM
Keenov's Avatar
I have no idea about those. I used the Stage 8 locking bolts on two cars and they are working fine.
Old 12-06-2004, 11:25 PM
2MuchRiceMakesMeSick's Avatar
I reused my stock bolts and they worked fine. All of my freinds use stock bolts also.
Old 12-07-2004, 12:20 AM
boosted03cobra's Avatar
you might want to fo ahead a change your plugs since your going to have them off anyway
