Tensioner Pulley
Old 12-21-2004, 12:04 AM
Silver02's Avatar
Default Tensioner Pulley
My tensioner pulley has been a little loud. Got a new Dayco 89015 but when I installed it, I found out it was binding and would not spin freely. The problem is that although the pulleys look almost the same, the washer binds because my original pulley has a taper on the inner plastic where the washer fits. The new one from Dayco is not tapered. Anyone have any ideas?
Old 12-21-2004, 12:59 PM
Silver02's Avatar
ttttt
Old 12-21-2004, 04:49 PM
Another_User's Avatar
Did you get the right one? There is an idler pulley, and a tensioner pulley. Dayco makes both, and I think they probably look similar. I am running the Dayco tensioner pulley on mine, and it was exactly like the original. Are you sure you didn't put it on backwards? Because that is the right part number.
Old 12-22-2004, 03:06 PM
Silver02's Avatar
Definately. It's the tensioner pulley. The problem is that every parts store shows the replacement pulley having a flat surface on the inside diameter of the plastic pulley.
My pulley is the same size (70mm) as the listed part which is a Dayco 89015 but the inner diameter on mine is beveled. Anyone know anything about this? I've seen some Gates pulleys at Napa that were beveled but they were too large.
Old 12-22-2004, 06:00 PM
Silver02's Avatar
Help!!!
Old 12-22-2004, 09:32 PM
I wish I could help more. More Dayco pulley was a perfect fit, so I don't understand. Maybe you should make sure they didn't have the wrong one in the box.
Old 12-23-2004, 08:32 PM
WILWAXU's Avatar
Have you tried a washer?
Old 12-24-2004, 10:59 PM
Silver02's Avatar
The problem is that the washer is binging on the inner diameter of the new pulley. Now , a guy from Gates told me that I don't need to use the washer. Seems like the washer helps to align the pulley making sure it is centered.
Old 12-25-2004, 09:22 AM
The bolt for my pulley had an end on it that helped align my pulley...are you using the right bolt?
Quick Reply: Tensioner Pulley
