help oil in my anti-freeze 3.8L
Old 01-14-2005, 12:12 PM
biomedengny's Avatar
Default help oil in my anti-freeze 3.8L
In my 1996 camaro 3.8l I've been getting oil in my anti-freeze and overflow tank for awhile now but noting in motor or anywhere else just in anti-freeze. the car runs good and never overheats.
Old 01-14-2005, 12:20 PM
Oscar Will's Avatar
Could it be trans fluid....instead of motor oil?? Your trans cooler could be leaking into your cooling system if you have an auto trans. Check your ATF...see if it shows evidence of water (it'll look like Pepto-Bismo). Usually if trans fluid gets into your coolant it gets real gummy and brown, fools some people into misdiagnosing the problem.
Old 01-14-2005, 02:15 PM
WAHUSKER's Avatar
That is what mine turned out to be. I replaced the radiator & viola, problem gone! Wipe the gunk on the over flow dipstick onto a paper towel & smell it. See if it doesn't smell like tranny fluid + coolant. (check by wiping the oil dipstick onto another towel with some coolant next to it...tranny fluid has a very different aroma)
Old 01-15-2005, 06:33 AM
smokin' joe 00 ss's Avatar
3800 are known for bad intake gasket's which will cause your problem I've had to change a couple of them on different vehicle's. They also had some problem's with crack's in the intake too, GM had some bulliten's out on this problem.
Old 01-15-2005, 03:43 PM
ls1_doc's Avatar
Yeah most likely it is the intake gaskets. We get a couple of 3.8 and 3.4s a week with bad ones.
Old 01-20-2005, 02:10 PM
thanks guy's alot i'll keep you posted
Old 02-05-2005, 06:58 PM
ls1_doc's Avatar
Ever find out what it was?
Old 02-07-2005, 08:34 AM
Not Yet Its Been Like That For Years So I Think That Guy Above Was Right The Raditor Most Likely Is It I'll Check When The Weather Gets Better
