gmmg or true duals or stick with slp d/d?
Old 01-15-2005, 10:02 AM
ss2000's Avatar
Default gmmg or true duals or stick with slp d/d?
hi, i did a search and couldn't find much on the slp dual/duals. my setup is jet hot long tubes with ory and the slp d/d cat back. i'm putting in an fms f13 cam and want an exhuast a little louder than what i have now and flows well. any thoughts? joe.
Old 01-15-2005, 10:54 AM
Hardtop00SS's Avatar
well I had all three so I'll give my opinion, all these are with QTP 1 3/4 LT's and a Mufflex ORY, and a TR224/112 cam....
SLP D/D - sounded nice with the LT's, ORY, was a little quiet, but I had a QTEC in the I pipe for when I want loud , a very stealth, nice setup for the street, with VERY little rasp.
True Duals - Obviously I didn't use the ORY, but I used a ORX, it was a 2.5 system with moroso spiral flow mufflers dumped before the axle. Duals sounds awesome with LT's, cam, but I ditched this because without cats, the fumes were pretty bad inside the car, but the resonance wasn't bad at all with the duals....
GMMG - I currently run this and I am VERY happy with the setup, this is a loud setup also, louder then my TD setup above, but has a very unique sound that people tell me sounds like not most other F-Body's. Rasp is kinda bad at 1800-2100, but the music after that makes up for it. I am thinking of sticking with this setup, but the resonance at highway speeds with the windows up is enough to drive you nuts.
hope I helped you out some
Old 01-15-2005, 11:50 AM
smokin' joe 00 ss's Avatar
The cam will make the D/D louder and if you go with heads in the future too it will get even louder.
Old 01-15-2005, 12:02 PM
cm02WS6's Avatar
See how you like it with the cam first, because the cam should make it louder.
Old 01-15-2005, 01:34 PM
Bad Blu Formula's Avatar
Like cm02WS6 said, try out your dual dual when you get the cam. If you think its too quiet, I say go with the GMMG. That is one of the most amazing souning catbacks aroud. Yeah, its a little pricey, but its all worth it.
Old 01-15-2005, 04:03 PM
Ryan02SS's Avatar
Why spend all the $ on a GMMG system or TD's when all you have to do to achieve a louder car is spend $179 on a QTEC in your I pipe. Open cutout at the flip of a switch with the F13 will be plenty loud. HTH
Old 01-15-2005, 05:17 PM
Crazy Man's Avatar
Check out the texas speed true dual rumbler x it sounds great the only thing is you lose your exhaust tips.
Old 01-15-2005, 06:00 PM
I only spent $350 for my GMMG, used....
Old 01-15-2005, 06:10 PM
tim99ws6's Avatar
True duals, Hands down
Old 01-15-2005, 06:46 PM
ONGRNGO's Avatar
I agree 100% on the True Duals I love mine and will never go back to a Y-Pipe setup!!
Dan
Old 01-15-2005, 07:04 PM
2MuchRiceMakesMeSick's Avatar
Dan
My vote is for true duals. They flow better and with sweet thunders they sound bettter IMO.
It all depends on what you want. www.ls1sounds.com might help you in your decision. In my experience I have seen D/D are the quietest, then gmmg, then true duals w/dumps are the loudest. Good luck
Old 01-15-2005, 07:19 PM
luv2spd's Avatar
I'd say wait and see how you like it after the cam. Adding the torquer cam made my exhaust much louder although its a magnaflow instead of slp d/d.
Old 01-15-2005, 08:44 PM
LS1Maniac's Avatar
TSP True Duals all the way. I'll never go back to a Y-Pipe setup!
Old 01-16-2005, 04:26 PM
ZR2877's Avatar
Like He said. No more ORY for me.
Old 01-16-2005, 04:54 PM
cyphur's Avatar
Wish I could find a deal like that!!! I'd buy that in a heartbeat for $350 for a genuine GMMG catback.
Old 01-16-2005, 06:15 PM
my GMMG might be up for grabs in a month, still deciding wheather I want TD's or not...
Old 01-16-2005, 08:54 PM
Rajun Cajun's Avatar
Would some dyno mat help with the noise?
Old 01-16-2005, 10:36 PM
5POINT7's Avatar
True duals.
I had a QTEC and it wasn't reliable. Kept burning fuses, then the motor went and I had to send it in to get replaced.
I now have true duals and have no regrets except ground clearance, and I'm already used to that.
Old 01-17-2005, 12:24 PM
99ssleeper's Avatar
Stick with the D/D....once you have a cam you'll love it.
Old 01-17-2005, 12:39 PM
mike#9's Avatar
I beg to differ......TD's with dumps are not as loud as my H/C (230/236)..LT's w/ ORY and Loudmouth.
People like making fun of it over the internet...but there is not a single person that has ever heard my car in person that has not liked it....we are talking dozens of people (at car shows, track, and on the street).
