Texas Speed True Duals
Old 01-16-2005, 12:19 AM
52172's Avatar
Default Texas Speed True Duals
How Are The Td With A Lowered Car? I Am Running The Mac Springs And Qa1's And It Rides Pretty Low!!!! Right Now I Have The Slp Y Pipe Which Is The Low Point Of The Car And Am Wondering If The Td's Would Lower The Low Point????????????
Old 01-16-2005, 05:07 PM
69_YENKO's Avatar
its probably going to cost you a little clearance, mines about an inch lower than stock and i have only about 4"-5". if your lowered to much your gunna drag coke cans down the street the SLP stuff is low anyways so it my not be to much of a differance, not sure?
Old 01-16-2005, 08:11 PM
52172's Avatar
thanks
Old 01-16-2005, 10:30 PM
tomaSS's Avatar
My duals hang low. I wouldn't recommend them on lowered cars although some people do.
Old 01-16-2005, 10:45 PM
fasthwks's Avatar
I tried mine with 1.5 drop and ended up taking them off, I just did not want to scrape everything and I could not even get into my garage with them. The bullets is where I had lost most of my clearance and I thought I had them up really tight.
Old 01-16-2005, 10:49 PM
Crazy Man's Avatar
I wouldnt want to drop mine with the exhaust i have now its just like Texas speed rumbler true dual.
Old 01-16-2005, 11:04 PM
deviate42's Avatar
3" duals killed my clearence
i was lowered 1 3/4 and scraped my turndowns off
Old 01-17-2005, 08:23 AM
m6z
m6z's Avatar
1 Am Lowered With A Pro Kit And Have Tsp Duals. It Works You Just Have To Be Carefull. I'll Try To Get A Few Picts.
Old 01-17-2005, 08:32 AM
1BADAIR's Avatar
I had the SLP Y with my eibach's it was only and inch off the ground. I have more clearance now with Jet hots and true duals
Old 01-17-2005, 02:02 PM
shep28's Avatar
My car is lowered and I think my duals tuck up pretty well. I banged in my drive shaft tunnel a bit and ground down an edge of my tranny cross brace. I have not scraped yet, but understand that I don't carry around "large" passengers or loads. I also bought an aftermarket toque arm. That one mod gave me much needed room to tuck it up even more. I am going to install some tubular sub frames, so that if I do scrape, the subs will scrape and hopefully not the duals.
Old 01-18-2005, 04:56 PM
m6z
m6z's Avatar
heres some picts
Old 01-18-2005, 06:58 PM
SVTlightning87's Avatar
how much is your car lowered?
Old 01-18-2005, 07:20 PM
LS1Maniac's Avatar
I don't think that is lowered, it looks at lot like my tsp duals.
Old 01-18-2005, 07:52 PM
5POINT7's Avatar
I think the pics are with a pro kit.
I've got the same springs with true duals. You'll be fine if you be careful. It's all in how well you get the duals tucked. There's a million and a half ways to mount TSP duals, it takes a while to get it right.
Old 01-18-2005, 08:20 PM
777's Avatar
if that's the case you need to have your exhaust fixed because there is no way that is not lowered at least and inch or two...i have seen tsp duals with a full soda can of clearance...
Old 01-18-2005, 08:46 PM
LS1Maniac's Avatar
I might just be underestimating my clearance. It feels like that's all the clearance I have sometimes lol.
Old 01-18-2005, 08:57 PM
777's Avatar
haha...i wish everything tucked up like the vettes!
Old 01-18-2005, 11:02 PM
m6z
m6z's Avatar
yes those picts are with a pro kit
Old 01-18-2005, 11:15 PM
SScam68's Avatar
Here are some pics of mine. My car isn't lowered but figured it might help. I can still tuck in the bullets a little better but nothing really drastic.
I have scraped them on speedbumps before
FWIW
Attached Thumbnails Texas Speed True Duals-clearance-1.jpg   Texas Speed True Duals-clearance-4.jpg   Texas Speed True Duals-clearance-2.jpg   Texas Speed True Duals-clearance-3.jpg
Quick Reply: Texas Speed True Duals
