Edlebrock Slip-on Merge collectors? How?
I've been extremely fustrated with the " slip-on" collectors. I can't seem to get them on far enough yet. I've only been on the Drivers side for about 1 hour an can't get any more progress out of it.
Anyone have any good ideas?
I'm going to try heating the collectors in the oven to about 500 F to try to help it along, but may just have to get a torch.
UNDER PRESSURE MOD
Try to rotate them 90 degrees to see if they will line up better. That's what I did and it worked for me. I used a deab blow hammer and proceeded to 'seat' the collector.
Unfortunately, while bolting up the driver's side, I snapped the first bolt and stripped the second bolt, so the head had to come off and get those two bolts helicoiled. I'm in no rush considering I have 14" of snow on the ground.
Good luck and let me know how you make out.
UNDER PRESSURE MOD
Richie, I ran into a similar problem as you when I tried putting my merge on the driver's side.
What I found helped was to install the merge on one primary at a time to where it only slides on the one collector at a time. This was to make sure that they would fit and that none of them were out of round or improper diameter ect.
Then I just sat down, patiently starting to try and find the best fit, rotating the collector 90 degrees each time.
I finally found it and slipped the collector onto the header. It only went on about a half an inch at first.
I then turn to a dead blow hammer and began to hammer it on. Don't worry about denting anything, it's quite strong.
Finally, I grabbed the header and slammed the collector against a peice of carpeting on the floor in the garage and the collector seated perfectly fine. I was hesitant at first, but it worked out fine. No dents or dings or damage of any kind.
Thanks man. That sucks that you have all the snow out by you. I'll get some exhaust clips and some pics up when I'm done. Should have track times too.
I've been pounding the hell out of the Drivers side for a while now. I might have ended up with it not being where it wanted to be, but I can't get the collector back off so I just have to keep going. The Passengerside shouldn't be as bad as this. I think It was impatience playing a big part. Man this coating is going to hold up. Torching the collector to get it in place and the coating really isn't phased.
I think you already got it .but I ended up starting them with some oil then holding the header and slamming down the collector on a piece of 6+6 until it mated up right.oil does wonders . or one will work
