Installed long tubes, HELP
The car is constantly popping and running rich after installing the Edelbrocks. I can cruise along slowly, but any major amounts of Throttle causes the car to buck and sputter. Seems like it is running extremely rich, but the o2's are reading just a little lean (-5 LTFT). Sometimes the when the is popping the LTFT are going rich (up to +4)
I need help. I can't get my tune from Diablo yet on my car until I get a USB to RS232 connector. He sent me a tune to Adjust for the Newer injectors. I had to run open headers for about 15 miles to get back to the house. The o2's are about 1 1/2 from the opening. Would this kill the O2's? Also I think I read somewhere that the Rear O2's from a vette are good to use for the Heatingissue I've read about.
I have o2 sims also.
Sorry I can't help you with this, maybe try replacing the front O2's with the one's you took off the back to see if you have a bad O2 sensor? I would try posting in the PCM Diagnostics & Tuning section there are some bad *** tuners in there if they will help you.
LS1 Tech Administrator
If you have the Edelbrocks with the slip on collectors, be aware that they are most likely sucking air in through the cracks where the primaries slip into the collectors. This will totally screw with the O2 sensor readings, making tuning in closed loop nearly impossible. Best solution is to weld up the inside and outside of the primary tubes as they enter the collector. Sorry for the bad news. Do a search on Dyno-Tech headers or slip on collectors and you'll see what I mean.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
