is there a lightwieght battery?
The only batteries that are significantly lighter than a stock battery are the dynabat and the generic one that is made by the people that make the dynabats, forgot the name. You will need a bracket made to mount it in the stock location though, but you could just relocate the stock on to the rear if you want to remove weight from the front of the car for alot less.
Here's the battery I have: http://www.gotbatteries.com/Productp...ctNum=37L105S1
So far no problems with starting or running the battery down although I do not run my fans with the engine off for very long.
Very simple to make this bracket from aluminum: http://www.mustangmods.com/data/440/battery.jpg
I can go back to a factory style battery in about 10 minutes. I kept the same connecting bolts to battery by making a couple of attaching pieces out of steel and tapping holes to mount.
Originally Posted by My84Z
where do i get the special adapters to connect our terminals to it?
Search is your friend -
https://ls1tech.com/forums/showthrea...=light+battery
I have the Hawker Genesis battery, only install it once in a while to drop a few pounds from the front and keep it charged up. It ran in the car full time for a month or so with no problems at all, but I threw in an Optima red for daily driving duty.
The battery comes with new bolts to put into the factory cables, or you can buy the adapters so you can use the factory bolts/cables.
Bad30th
Bad30th
Thanks for letting me know the search is my friend as I did search and only came up with battery's that needed new brackets and such like the one you pointed out that is why I asked for one that goes in like stock. However thanks for the help I think I decided on that one. Thanks for all the help guys.
Originally Posted by BTLFEDSS
Lane or any oneelse can the SVR 14 be used as a everyday battery or is it not strong enough for everyday
Thanks BTLFEDSS
Thanks BTLFEDSS
They're sweet little batterys. Knocks off an EASY 20 lbs or so from the stocker I believe. You can hold it with two fingers...
Lane do I need a post kit of some sort?
Here's a pic of the connector arm I made. My photography isn't that good but hopefully you get the idea. Of course you will need two.
http://www.mustangmods.com/data/440/arm.jpg
