How much for Cat-back install these days?
You shouldn't need to weld, clamps will do fine. Or you can clamp it and take it somewhere to get welded.
I personally am sticking with clamps, because I'll need to switch my Y pipe in and out between a catted version and a non-catted version, depending on if it's that time of the decade (E-check).
LS1Tech Administrator
Received 1,493 Likes
This is a pretty easy DIY mod. I'm picky about mounting of exhaust so I always do that myself. A full catback install on an LS1 should not require any welding. I've done many, many, many catback installs on LS1s and never needed to have anything welded.
PS. Sawzalls are fun.
Don't be scared.
They are your friend.
It's one of my favorite tools.
I like my old Milwaukee Sawzall, it's an early '80s model that takes a beating like a rented mule and just keeps asking for more.
Don't be scared.
I did my cat back install myself because I didn't want to pay the $100 fee....it wasn't too bad. It just took some time to line everything up correctly...and you might want a friend to help you line up your tips so they match.
id just clamp it on yourself. then if u decide thats the sound u want, go get an exhaust shop to weld the cracks up. or maybe u know someone who can weld it. it aint hard at all.
If you've got a jack and jackstands, definitely do it yourself - if you can change your own oil you can install a catback! It's also a good excuse to buy a sawsall!
I would recommend picking up some band clamps instead of the crappy muffler clamps you get with most catbacks. This way, you won't crimp the pipes when you tighten everything up. Makes it much easier to adjust after tightening everything up and you won't damage the system in case you ever want to sell it, etc.
If you do use the muffler clamps, be sure to adjust/tighten in small increments and always tighten from the front to back - you'd be surprised how much things start moving around when you tighten those clamps!
I actually use the oppsite tightening system for catback installs. I put everything on, leaving the clamps all semi-loose. Then, once I get it setup right I start with the back and work my way to the front (middle) of the car, tightening slowly as I go...... seems to work better for me in keeping the original adjustments in line.
