02 sensors
Possible Scammer - Buyer Beware - Issues Unresolved
Originally Posted by artic-z28
Does it make a difference on which 02 sensors you use for the LT's? , I used the rear ones....
LS1Tech Administrator
Received 1,493 Likes
Originally Posted by Bluehawk27
You need to use the front ones. The rear ones only measure CAT converter Efficiency.
I used one of the rears in the front on my WS6 without issue, it was like that for about 2 years. The wire was a better lenght so I swapped them. Never caused me any issue, and the readings were in line on a-tap from bank to bank. No SES, no tuning issues, no running problems from doing this.
I'd have to say yes, in my experiance it's fine to swap them around.....
1 Post
i have an ses light and went to autozone. it was the o2 sensor. how do i know which one is bad and how much would it cost to fix. i had my headers on for about 4 months and the light came on yesterday.
you can use the rear sensors in the front locations as long as the connectors on the ends of the sensors are the same. 04 vette's have different connectors for front and rear applications. To use the rear sensors in the front locations on these cars you have to have an adapter to convert the male plug on the o2 wire to a female plug in order to plug the rear o2 into the front o2 harness.
The usual replacement for o2 sensors with LT Headers is to use the rear o2s from a vette. They have a 24" pigtail so you dont need to use extensions, and they have a higher wattage heater which help the sensor function better in the cooler exhaust stream. (The exhaust gasses cool off as they travel through your header towards the collector and the sensor). These cleared up my insufficient switching codes my car was throwing. I used bosch part number 13111 from autozone.
