Cut-out cap blow off! Where can I get another one???
Old 02-24-2005, 12:47 AM
WIKDWS6's Avatar
Default Cut-out cap blow off! Where can I get another one???
I was driving on the highway with my cutout, capped then I down shifted to 4th to pass, and the lid start to open (could tell by the sound of the exhaust),
so before I could slow down and tighten it, it blew of into the ditch. This is a manual 3" cutout. Does anyone know where I can get a new cap, gasket and 3 wingnuts?
Old 02-24-2005, 01:11 AM
01_SuperSlow's Avatar
You might be better off just buying the whole thing again. It's only 35 bux.
Old 02-24-2005, 12:05 PM
WIKDWS6's Avatar
Yea I could, but pick'ins are slim in college.
Old 02-24-2005, 01:11 PM
psykoTA's Avatar
Get a hold of some metal. Get a grinder, cut out the shape, drill three holes. And buy a gasket.
Old 02-24-2005, 01:17 PM
psykoTA's Avatar
How thick is the steel used for the cap?
Old 02-24-2005, 03:06 PM
HAUS1's Avatar
The thickness should be heat resistant and all it needs to do is block the exhaust air flow. I would say 1/2" to an inch thick should do the trick.
Good Luck!
Jon
Old 02-24-2005, 03:33 PM
cyphur's Avatar
a full inch thick? you realize how thick of a metal plate that is?
go to any welder's shop and they should be able to hook you up with some scrap metal for free. 1/8's steel sheet will do(appx thickness of cardboard) and do psykoTA said. cut it out and drill some holes. then pick up another gasket and 3 wing nuts.
Old 02-24-2005, 03:41 PM
smokeum99ta's Avatar
Just like cyphur-traq said with the welding shop but 1/8" is kinda thin.I think the original cap is 3/16"or 1/4" think to prevent warping. Maybe next time use some lock washers with the wing nuts to keep them from rattling off again.
Old 02-24-2005, 04:45 PM
GuitsBoy's Avatar
LOL @ the full inch thick plate steel doing the trick! Seriously, when was the last time you saw a melted and warped exhaust pipe? You simply dont unless it was heated with a torch. Exaust pipe is 1/16 thick. Thats probably the thickness the original plate was as well. Stepping up to 1/8 is already plenty. Some time with a grinder and a drill is all it takes. Good luck grinding through that inch thick plate steel It would be easier to cut your lawn with tweezers.
Old 02-24-2005, 06:16 PM
8-Pack's Avatar
not to jack this thread but I got to ask, HAUS1 is that fake formula badges **** in your sig for real? Why?
Old 02-24-2005, 06:42 PM
psykoTA's Avatar
I agree 1/8" is plenty.
Old 02-24-2005, 06:53 PM
Blue02Ws6's Avatar
wow, look at all the replies.... All you need is an exhaust block off plate for a 3" flange. ANY decent exhaust shop should have one of these and it will be less than $35 unless they are idiots trying to rip you off. Should cost about $5. As for wingnuts just go to any hardware store and pick some up. Why do people try to overcomplicate things?
Old 02-24-2005, 08:36 PM
HAUS1's Avatar
Yes because Rookie's like you make me laugh
Old 02-25-2005, 10:44 AM
8-Pack's Avatar
Guess a couple posts and a few months make a huge diffrence. Sorry I cant get behind a computer as much as I would like to. Anyway are the fake badges a joke?
Old 02-25-2005, 10:53 AM
8-Pack's Avatar
Just finshed reading most of your posts. Guess you DO have a formula. Cool anyway congrats on the new car (since you just got it a few months ago)
Old 02-25-2005, 09:12 PM
67SS&99SS's Avatar
You can order them from flowtech. I had a sheet of paper that came with my cutouts saying that you could order another plate, 2 gaskets and 3 more wing nuts for $9.95 + s/h
Old 02-26-2005, 03:11 PM
WIKDWS6's Avatar
Do you have Flowtechs phone number?
Old 03-01-2005, 12:45 AM
WIKDWS6's Avatar
Anyone have Flowtech's phone number?
Old 03-01-2005, 01:00 PM
67SS&99SS's Avatar
I'll get it for you today possibly, if not, then definately by friday.
Old 03-01-2005, 01:12 PM
psykoTA's Avatar
Call Holley, theyll be able to patch you through or give you a number to the Flowtech Facility.
