closest elbow on passenger valve cover
on the passenger valve cover the first elbow where a hose goes from it to the throttle body what is it for is it to let fresh air into the valve cover or to suck pressure from the valve cover into the throttle body similiar to the pcv valve if so why couldnt i close off the throttle body elbow and run that line into the pcv valve line? would that work? gains and negatives of doing this right now i have it capped off with a lil filter on the valve cover elbow thanks guys
If you took off the TB elbow and put that into the PCV line, then you'll suck the oil out of the crankcase and into the intake.
You'll still have the intake pulling vacuum in the crankcase.
And if you put a filter on the other side of the tee, then you'll have a massive vacuum leak.
Why are you trying to delete the TB hose?
If you just want to make things look nice, then drop the whole PCV system entirely and just put breathers on the valve covers. Just make sure to cap the TB elbow and the intake port where the PCV valve enters.
Jantzer sells some nice smoothed valve covers. Then you could relocate the ignition coils to the back of the engine and achieve a nice clean look.
Well that ain't good! Could i run a hose from driver back elbow to passenger back elbow to passenger front elbow then to a catch can then to the intake without a pcv valve in the line. or skip the catch can and put a pcv valve in there just trying to get options here thanks for all the help on this i am not the best on this pcv stuff
