160 Thermostat
Originally Posted by LSTSS02
Anyone know if I change my thermostat to a 160 degree if I will trip the SES light?
Thanks!
Thanks!
Originally Posted by DravenMyers
It shouldnt as long as you dont leave nothing disconected as in any wires.I just ordered mine today I will put it on with my cam and tuneing
Ok......I was curious as my 97' Ram Air LT1 did trip the SES light........
did you scan it to see why it kicked a code I have changed thermostats on LT's with no problems
Seems this LS1 is pretty quick though....02' SS 345HP (Stock)
Def. shouldn't throw a code. And, it's not going to do much at all for your car until you program your fans to turn on at 160 as well. I used a hypertech to do that when I got my 160 stat and it runs ~185 all the time now. Before it used to run 195-200 consistently.
1 Post
Schantin
2002 Camaro Z28 M6
Ordered one of some guy on ebay and I'm going on 3 freaking weeks and havent recieved it yet. Damn i'm about pissed. Its only 45.00 but damn I hope I didnt get ripped. Guy sells them cheap as hell so maybe a few of you got yours from him, guys screenname is masterpah.
Originally Posted by Y2K SS
Is it even worth putting in on a LS1??
Other then that you don't cook your engine/oil it will survive more abuse.
It shouldn't give you an SES light.
You should take the stock one off and inspect it though.
Mine stock t-stat had only 41k miles, I took it off to inspect it during my last cam swap and found the rubber gasket on it all cracked up and caught inside the thermostat spring. Luckily I had a new 160 t-stat that I didn't install when I did my first cam swap.
