what style of header gaskets to use?
Old 03-30-2005, 07:00 AM
sbmjohnson's Avatar
Default what style of header gaskets to use?
I just installed a pair of TPI long tube headers with Random Technology cats and cat back system. It sounds and performs great but with a noticable left bank exaust leak between the header and the head. I installed OEM gaskets but now I should of thought it through. What kind of gaskets did you use that works the best. thanks, brent.
Old 03-30-2005, 07:06 AM
It's not mine! woo hoo!
demonspeed's Avatar
Everyone uses the OEM copper ones AFAIK....
Old 03-30-2005, 08:48 AM
jmm98LS1's Avatar
I reused the stock gaskets with 55k on them....two years and no leaks.
Old 03-30-2005, 09:21 AM
code4's Avatar
Factory GM steel gaskets are the best.
Old 03-30-2005, 09:26 AM
REDLV SS's Avatar
reused the stock gaskets here also. 2 years no problems. Stick with the factory gaskets
Old 03-30-2005, 10:15 AM
SSU's Drunk Typing Whore
Lithium's Avatar
Same here
Old 03-30-2005, 10:19 AM
mike c.'s Avatar
factory here.
Old 03-30-2005, 11:02 AM
bowtieman81's Avatar
I resued the factory exhaust gaskets; all I did was take some scotch brite and rub the rust stain off them (from the cast iron manifolds, the gaskets are actually stainless steel). They worked great. You may need to check the torque on your header bolts, sometimes they loosen up after a few miles.
Old 03-30-2005, 12:13 PM
scorched_ss's Avatar
Percy's ''Dead Soft'' Header Gaskets from jegs - had them installed when I put the new motor in - they looked too thick to fit but I think they're sposda work like a sponge almost... so far so good...
Old 03-30-2005, 12:38 PM
macool68's Avatar
another vote for the stockers
Old 03-30-2005, 07:54 PM
Cstick's Avatar
I used fel-pro replacement gaskets. No problem. If I had known that the stockers were multi layer I would have just reused them. I kept them if their is a next time situation. I would lay a straight edge on the header to make sure it is not tweaked.
Old 03-30-2005, 10:06 PM
sbmjohnson's Avatar
thanks guys for the advice. I found that the left header flange was slightly bowed causing the leak and the OEM gasket did not seal. I found a pair of fel-pro gaskets that might do the trick. If that dont work I will beat it with a big hammer.
Old 03-30-2005, 10:52 PM
ddelallata's Avatar
big phucking hammers always work. Well, almost always
Old 03-31-2005, 07:08 AM
jj_z28's Avatar
Stockers for sure
Old 03-31-2005, 08:22 AM
m6z
m6z's Avatar
ya, stock ones with 50k on them no leaks.
Old 03-31-2005, 12:20 PM
LoPeY's Avatar
I used the paper ones that SDPC sent me with the Kooks. They're slowly starting to burn away.
Old 03-31-2005, 01:47 PM
240M3SRT's Avatar
LOL i hope your kidding.
Get it decked at a machine shop. I wouldnt want to see you have to do the job 3 times.
