slp ls6 intake w/ egr
an ls1tech board member didnt tell me that theres no brass fitting nut so now im screwed and i now have to remove the egr cause no one seems to have a compression fitting that big.
now how do i block off it off? tehres a ******* compression fitting on there.
im getting some block off plates for the manifold from ls1 speed tommorw.
but i called them and they said that there freeze plug cant be used on the slp intake.
Help!!
Help!!
Help!!
Help!!
I can send it to you if you need it.
If you dont have any of the fitting at all sorry i couldnt be more helpful.
I just used liquid steel a type of JB weld to seal up the hole in my intake.
I know Amit looked everywhere for one.Unfortunatly I already sent him mine.
The only thing I can suggest is to google for brass compression fittings or brass ferrules.Then start calling people to see if the can help.The only other thing since Slp doesnt want to help,or help Amit for sure is to delete it all together.
Maybe you can get a shop that sells the intake (like speed inc) to get you the nut and ferrule.Im sure Slp would help a shop.
the company that makes that part is called Swagelok.
try calling them direct.. thats what i did. i sent them an email with lots of pics. hhaha.
i think its www.swagelok.com
