Help Me!!
Help Me!!
How Can You Tell When You Need New Plugs, Wires Or Cats, Guys?
My Car Has 85,000 Miles (mostly Freeway Driven) On It. No Misfire And No Codes! When I Am At Low Speed Low Idle Then Give It A Little Gas I Hear A Mild Sound That I Think Is Coming For The Cats. And The Last Couple Days The Car Does Not Start Right Up. The Starter Is Turning A Few Times Before It Starts! And If I Have The Gas Pedal Down And Start It Then It Makes A Rapid front Exhaust Type Clicking Noise. That Noise Is Only Heard When Starting The Engine! Help Me Please Guys The Search Button Is Use Less For This Situations.
Just to start off...
If you have 85k miles you are defintely due for a tune up. I would do new spark plugs (NGK TR55's gapped somewhere between .050 & .060), new spark plug wires (MSD, Taylor), and fuel filter.
You should not have to give it gas to start it.
As far as the cats being bad, I believe there would be a code for this. Correct me if I am wrong.
On another note...
Compass and thermo rearview mirror (in your sig), how did you do it? I have been thinking of doing this.
On another note...
On another note...
On another note...
Originally Posted by CW01WS6
They need to be as close as you can get them. I'm real maticulous about that sort of thing so I would say yes they need to be exact. Anyone have an actual answer?
Mine were all slightly off from one another. You ALWAYS check the gap and regap the ones that are off.
