Both fans will not come on at all
I started using my A/C now here in South Florida. My temps no matter what kind of driving I do NEVER go above the 155 white tick mark on my temp gauge (regardless if its accurate), now when I turn my A/C on the temp goes straight past the 210 mark and my engine detonates like crazy, so its friggin HOT.
I got out of my car to listen for the fans and heard nothing. I also turned the car off, kept the key on and the A/C on "max" and the fans were dead stopped.
Shouldn't the fans be 'ON" even with the engine off and the key "on" with the A/C on "max"?
What can a brutha do????????? Both fans not working seems a little coincendental. The fans were working like a charm about a month ago.
maybe there is some wire loose or something, did u check the fuses and see if you blew one of those. and your engine detonates like crazy what do u mean does your SES light come on or does it run weird??
I never get SES codes/lights.
Where are the fan fuses at?
they should be testable by getting a fuse testor its a pointy rod thing with a light at the end and you basically ground it to something and if the light comes on the fuse is fine but if it doesnt the fuse is ****. and yeah they should be the big white ones one of them at least. check the fuse box cover the one under the hood.
Originally Posted by Quickin
What do I look for on these big fuses to know if they're blown?
the PCM commands the fan to run when the system reaches a certain pressure. when the engine isnt running, the A/C compressor isnt generating that pressure, so no, the fan will not come on. and look for high/infinity resistance to indicate a blown fuse. if you have a multimeter check th fan motors also. and the 3 relays under the hood.
OK boys, try to figure this one out.
I started my car a little while ago and let it idle in the driveway for 30 minutes, with the A/C on "max". The bastard never even reached the 155 degree mark. THE FANS started up as soon as I put the A/C on "max", they never turned off. I put my hands in front (behind really) and felt them both blowing hard. I also heard them kind of kick in a little faster while I was wiping down my engine and they started blowing alot harder.
So I figured WTF. I took it for a ride. The temp immediately went right up to 210 and then a little bit past it. Maybe 15 minutes of city driving. I pulled over. left the engine running and the fans were dead stopped the entire time.
I'm ready to tear both of these fans out, toss'em in the garbage and get all new wiring from the PCM on.
If I turn the A/C 'off" after its hot as hell, it cools down quick and the car performs perfectly with the temp never reaching the 155 mark.
Whats going on man? They don't work once the car is hot
watch out mechanics and let an electrician in here...lol
i would get a haynes repair manual on your car. in the back they have wiring schematics of everything on the car. there should be a schematic of everything on that from the pcm to the fan itself. if theres problem with the circuit or if there is another fuse or relay somethere that is causing the problem you could locate it.
The problem is: After the engine gets too hot they will not come on. I pulled over today after the temp needle went past the 210 mark and they were not on and they would not come on. I had to shut off the A/C so the engine could cool down.
It seems that when the car is hot and the A/C is still on, the fans will simply not come on anymore. If the car is hot and the A/C is turned off, everything is just fine and the fans are awesome and the car will never get hot no matter how I drive it.
what thermostat do you have in there? did you check the relays like i said?each relay has its own fuse to check. and there are enough electronic troubleshooting sites on the internet for me to not have to repeat myself on how to check resistance.
I'm mechanically declined man, I don't know where the relays are. Let alone have a meter to check anything.
Looks like a trip to the dealer is in my future.
Originally Posted by Sebring 00
Beg to differ with you Sir. A high resistance indicates a GOOD fuse.
maybe it is a pcm problem and not an electrical problem. the fans ARE working just at the wrong times. maybe you could have a scan tool hooked up to see what is goin on. perhaps the pcm does not know when to turn them on or its getting an innacurrate reading from a sensor somewhere...you never know.
although it could still be electrical. there are going to be several relays and fuses between the pcm and the actual fan. you could have a relay that is sticking, or isnt staying closed when you turn the ac off. i dont know ive never really tore into that part of the wiring.
never know till you check. but the whole thing sounds like a thermostat or temp sensing problem to me.
Restricted User
Check them with a multimeter set to Ohms. No reading or next to nothing means the fuse is blown. NAPA has them in my area.
