Traction control ? do i have it or not?
I was taking off my bezel around the stereo and HVAC and saw that to the right of my fog lamp switch there is that blank spot and when I went to remove it, it has several wires running into it? I know my 98 Z28 didn't have that and I didn't have T/C on that either, is that it or do they just run the wires there whether you have it or not?
its cheaper to make one wiring harness for all cars...then to make different wiring harness for different options. If you don't have the as button..you don't have traction control...I have it..its pointless...even n the rain and snow because it doesn't come on till the tires spin...and abrutly stops it which makes the car less balanced
