Problem with FAST intake
I took off my LS6 intake and started to put on my 90mm FAST intake but I ran into a problem. My coolant cross over line on the front of the cylinder heads will not let the intake set down on the cylinder heads. Its holding it up just behind where the TB would bolt up to it.
I thought about trying to bend them down a little but I'm afraid I'm going to cause them to leak because that line is so rigid and has zero flex.
I'm sure someone has had to run into this problem before.
Thanks,
Jeff
Thanks,
Jeff
Originally Posted by LawmanSS
I have read in past threads that you need to bend the tube down slightly..
Originally Posted by Hawkn01
LawmanSS is correct, you'll need to bend it down enough to clear. Also don't forget to replace the stock valley cover bolts with the one's that came with the intake.
I bought my intake from a person and they did not include them. However when I laid the intake down on the valley cover, I noticed they were kind of holding it up somewhat.
So, I am going to need to bend that coolant line As rigid as that line feels and as far as I am going to have to bend it, I fear for the result, but I'll try it tomorrow.
Do I have to buy those bolts from FAST or are they something I could pick up locally you think?
Thanks,
Jeff
You need button-headed allen bolts...M8x1.25x32mm (according to GM parts manual)...you should be able to find these locally...ACE hardware stores usually have a nice selection of metric bolts...
EDIT: The OEM bolts are 32mm in length, but 30mm will most likely be what you'll find and will work fine...
Jeff
I put a block of wood on my coolant tube & tapped it with a hammer until it fit (NOT much). And yes, get some button head bolts. At the least you will have a ton of noise coming out of your intake from sitting on the stock bolts. At worst it will crack it!!!
Thanks,
Jeff
