Pacesetters rusting because of AC. Any fixes?
Old 10-09-2005, 04:42 PM
Xtnct00WS6's Avatar
Default Pacesetters rusting because of AC. Any fixes?
I have a set of Pacesetter LT's and whenever I have the AC on and then shut the car off, get out, I can hear the sound of dripping water hitting my Long Tubes. It's hitting right on the collector and is starting to get some serious rust going. Does anyone have a way of deflecting, channeling the water away from my passanger side collector? Pic's would really help!
Thanks!
Old 10-09-2005, 08:44 PM
Xtnct00WS6's Avatar
don't say the fix is to get a stainless pair of long tubes too btw
Old 10-09-2005, 08:57 PM
CHIWS6's Avatar
good question because i have the same problem as well, so any1 ?
Old 10-09-2005, 09:23 PM
Xtnct00WS6's Avatar
Does anyone at least know where the water is coming from? It's hard to search under there after u've been driving it and the tubes are all hot.
Old 10-10-2005, 12:20 AM
Xtnct00WS6's Avatar
ttt...
Old 10-10-2005, 12:29 AM
Ghostintheshell's Avatar
condensation from the AC system of course...
As for a fix? you told me not to tell you . . .
Old 10-10-2005, 09:21 AM
Hennytime's Avatar
i would guess to try to make a piece of metal fit on top of the collectors, like a heat shield, only this would be a water shield?
Old 10-10-2005, 09:28 AM
Likestogofast's Avatar
what about trying some header wrap
Old 10-10-2005, 12:24 PM
Xtnct00WS6's Avatar
I don't think header wrap would work. I'd bet it would just soak into it and then end up doing the same thing. Is there a run off/drain type thing that's funneling the water to the headers collector?
Old 10-10-2005, 12:37 PM
01formula6's Avatar
Open the windows, shut off AC. Problem solved.
Old 10-10-2005, 12:55 PM
WS-Sick's Avatar
Are your headers coated? I don't have any problems with mine. They look like they did the day they were installed 2 years ago.
Old 10-10-2005, 04:38 PM
Xtnct00WS6's Avatar
Yep...they're coated. I've resorted to using a metal colored rustolium. What year is your WS6 WS-Sick? Mine is a 2000, but I'm not sure if that matters.
Old 10-11-2005, 04:02 PM
Xtnct00WS6's Avatar
ttt...
Old 10-11-2005, 05:38 PM
Dustin's Avatar
What is the temp of an exhaust? What about some heat resitant tape?
Something like this?
http://cgi.ebay.com/ws/eBayISAPI.dll...category=26248
Old 10-11-2005, 07:21 PM
Full-Force's Avatar
whats the big deal?
who is gonna see the rust?
its not like its gonna rust through the header, its only surface rust
