NEW 90mm Throttle BODY for LS2 Style intakes
Closed ex-Sponsor Account
Just posting up some pics..
The Throttle body has a peribolic bore, so no tip in problems, very smooth off idle throttle responce. You can see it in pic 3, only the top of the bore is opened off idle. The bottom stays closed.
Ricky
It looks like its made well but I have never heard of anyone having tip in problems. Most drive by wire TBs have a peribolic bore but its for idle control mostly. I think its got more left in it if it was ported, but its hard to tell by the one pic.
Sorry I can not talk price. The peroblic bore is a very trick way of doing a throttle body.. See the bore is not straight throu like other units out there. The 4th picture shows a small bore change in the lower area... What happen when you open the throttle blade just off idle, you are only opening the top part up, the buttom is still closed.. That way you do not get a ton air off idle. It s a clean opening... One thing too, took one apart, bufferly extremely clean and free.
Ricky
Ricky
Originally Posted by Ryan K
When will they be available? I'd like to do the LS2 manifold... Just need a good wired TB.
Ricky
