Just installed my March pulley!!
Not a bad install over all. I was a little worried about putting that much stress on the crankshaft threads to seat the pulley. I got the longer bolt to do the install and I would def. reccomend Hawks tool instead. I actually threaded my bolt in quite far by hand, started to torque it down and at about 180 ft lbs the bolt broke free. I was like oh ****, I just ruined the crank.
I couldn't understand it because it was not crossed. When I pulled the bolt out 1 perfect ring of the internal threads came with it. I blew out the hole with compress air dipped another bolt in oil thread it in and out a few times and proceeded to install again. Everything seemed to have went fine. I got it as close to 240 ft lbs as possible using my legs! Seems to be lined up got on it hard and it did not throw the belt. Hope i got it seated all the way back. could someone give me a measurement like from the back of the pulley to the timing chain cover.
Id measure for ya, but my engine is torn apart...doin a rebuild. But just wondering if you noticed any gains of some sort with this pully? Im thinking about gettin it, but not sure if its worth the 200 bucks? Let me know, thanks!
I really need to know if I have this thing seated all the way back. It doesn't seem to ba as far back as the stock one can someone help me out.
yeah its a march, if you search you may find it. look for a post by me back in about the end of may. someone came on here wiht spec on how far the crank snout was set in from the outter edge of the pulley. i wanna say it was about 0.140" but im not sure. prob wont help muhc if you have the bolt seated on there anyway.
