qtp off road y pipe
i had alittle hastle with there ory and took it to a muffler shop .they had to cut and re-expand in a couple places and it still hangs alittle lower than i like.for the price i would look elsewhere for the ory but the hvmcs are great !
I'm with slow trap. After the flowmaster collector there is a cone reducer which in theory is designed well, it just isnt compatible with all exhaust systems. My ory also hangs a bit lower then I wanted but the whole setup together sure does flow good. If you get a professional to install it you will be happy. Just dont try and do it yourself when your car is on ramps/jackstands. PITA!
pete...you'll be fine with the qtp ory... its very nice actually..with their true merge collector.. the mufflex y is actually very similar.. so either way you'll be ok..
