asp underdrive pulley
does anyone know the length of the belt you need when you have an asp pulley installed?
the instructions that came with the asp gave me a gates part number but im looking to try a different belt. any help would be appreciated.
thanks
thanks
Access. Belt #
11-755K6 (75.5 inches long, 6 rib)
11-770K6 (77.0 inches long, 6 rib)
11-760K6 (76.0 inches long, 6 rib)
The above are the belt numbers that thunder has on thier site. The belt part number is actually the measurement of the belt - gates uses similar part numbers on thier belts. So you can ask for a particular belt length by editing the part number/length.
thanks
thanks
Jim
LS1TECH.com Sponsor
The 755 is advised to be used unless you have an adjustable tensioner. The 760 often works its way off of the tensioner by a rib or two and with time will eat away the edge of the belt (unless you contantly check under your hood and put it back). Going with the 755 eliminates that. We suggest Goodyear Gatorback Belts as replacements.
