best 02 sensors
Kleeborp the Moderator™
With headers, any brand O2 sensor is a crap shoot. FWIW, I've had GM O2s that lasted for about a year before they got too lazy, and it was the same with the Bosch 13111 sensors.
Right now, I don't even have O2 sensors, and don't plan on ever putting them back in.
Originally Posted by BackinBlack02SS
Why do you say that?
Originally Posted by blkbird
:GuitsBoy: Im about to get some densos. What bad experience did you have?
It seems with long tubes, atleast with my car, both the stock delco and the bosch sensors will eventually start throwing codes after 10k - 20k. However the bosch are considerably cheaper and they perform very well, even when they do throw codes (and you disable the DTC with a tuner).
After going through 14 oxygen sensors in the life of my car, id rate the bosch as the best buy because of the extended wire, the heater, and the switching activity all for a decent price. The stockers are good also, but theyre more expensive and require extentions. The densos, however, I rate as **** poor.
Well, I guess I will save me some trouble and get the Bosch 13111. Im tired of seeing my SES light on all the time.
Originally Posted by jimmy 2 Times
a bit off subject, but why do they go bad? And how to you tell if they have gone to crap?
The symptoms you typically see with a long tube eader car is that the o2 sensors start to fluctuate (switch) less frequently. This usually trips the insufficient switching code and sets the SES light. Many things can cause the o2s to fluctuate slowly, such as too low exhaust temps, fouled and caked carbon deposits, lead and silicon poisining. Even if you eliminate all those possible issues, the sensors still tend to go bad with time and miles. You can pull the sensors out and clean them by hitting them with a propane torch for a few minutes to burn off all the carbon deposits, however usually after a few days the codes come back.
4 o2 sims instead 2 ?? and deleted with the tune?? What rims are you running?? They are sweet!!
