Clean the MAF?
Old 03-13-2006, 08:02 PM
FL01SS's Avatar
Default Clean the MAF?
Should I clean the screen on the MAF??? I don't know if that is a maintenance item on an LS1 or not. I just cleaned & oiled my filter the other day and I was looking at the screen and it looked clean and all, but I thought I'd ask. Especially since I've heard of people having issues if filter oil gets on it or the sensors. Should I spray it down with some sensor safe TB cleaner at filter cleanings, or just leave it the hell alone? Thanks.
Old 03-13-2006, 08:05 PM
J&J Speed Shop's Avatar
www.crcindustries.com has a new MAF cleaner spray
Old 03-13-2006, 08:15 PM
FL01SS's Avatar
Wowzer. Thanks for the quick reply
Old 03-14-2006, 12:53 AM
cowboysfan's Avatar
I clean it shortly after cleaning my oiled filter. if to much oil is sprayed on filter, it can be sucked thru and get on maf. so I purchased electrical cleaner in an aerosol can. works good.
fuerzaws6
Old 03-24-2006, 09:17 AM
Fratsit's Avatar
Anyone ever use this stuff? This is the first I have heard of it.
R/
Frat
Old 03-24-2006, 10:28 AM
rgaynor85's Avatar
yeah i seen it at straus the other day i used crc electrical parts cleaner on mine with a cu-tip very lightly to rub off the **** that wouldnt run off came out like new
Old 03-24-2006, 08:24 PM
daryl2cb@yahoo.com's Avatar
yeah the electrical cleaner should be just fine.
Old 03-25-2006, 05:05 PM
Fratsit's Avatar
Nice, thanks for the heads up. I'll check it out.
Frat
Old 03-27-2006, 10:28 AM
R/
Frat
Yes we use it here at the shop. It does work very good. You can probably pick it up at a local Carquest or NAPA auto parts store
