Autometer Gauge
Autometer Gauge
Sorry if this isnt the correct place to put this but wasnt sure. I did a search and came up empty handed. Was looking for any info on where to install the sensor for water coolant. And was also curious if any one has ever used just one gauge and had several diffrent sensor tied into a three way switch to use for water,tranny,and oil temps? Any help would be greatly appreciated thanks in advance.
I would personally install the water temp sensor in the cylinder head.
That's the place where you want to keep an eye on things.
As for coupling one, or more sensors together, you mightl have to calibrate
each sending unit if they are not original AutoMeter senders.
anyone who has put the sensor somewhere else? im not sure if i want to drill into my head , i just installed the oil press sensor on the bracket on the oil filter, so I got the drill and tap ready.
